跳转到主内容
Gateway MS2370 Keyboard Replacement
你所需要的
  1. Gateway MS2370 Keyboard Replacement, Battery: 步骤 1 中的图像 1,1
    • Make sure the laptop is turned off and flipped over so that the bottom is facing up. Then, locate the battery clip as shown.
  2. Gateway MS2370 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Either using your fingers or a plastic spudger push the battery clip to the left to release battery.
  3. Gateway MS2370 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Pull the battery from the laptop to remove it.
  4. Gateway MS2370 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Take the plastic spudger and pull up the tabs on all four sides of the keyboard molding.
  5. Gateway MS2370 Keyboard Replacement: 步骤 5 中的图像 1,1
    • Carefully lift the keyboard molding out.
  6. Gateway MS2370 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Use the plastic spudger again to pry the keyboard tabs from the laptop.
  7. Gateway MS2370 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Slowly lift the keyboard from the laptop.
  8. Gateway MS2370 Keyboard Replacement: 步骤 8 中的图像 1,2 Gateway MS2370 Keyboard Replacement: 步骤 8 中的图像 2,2
    • Carefully unplug the ribbon cable attached to the motherboard.
    • The ribbon cable is extremely delicate, handle with care
  9. Gateway MS2370 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Lift and remove the keyboard from the computer.
结论
另外一个人完成了本指南。
团队
UMass Dartmouth, Team S1-G5, Simcock Fall 2017 UMass Dartmouth, Team S1-G5, Simcock Fall 2017 的会员
UMASSD-SIMCOCK-F17S1G5
3 名成员
创作了10篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 5
总计 1,013
