跳转到主内容
Gateway MS2285 Hard Drive Replacement
你所需要的
  1. Gateway MS2285 Hard Drive Replacement, Turn Laptop Over: 步骤 1 中的图像 1,1
    • Turn the laptop over so that the underside is facing towards you.
  2. Gateway MS2285 Hard Drive Replacement, Unlock The Battery: 步骤 2 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Unlock The Battery: 步骤 2 中的图像 2,2
    • Slide the short slider one towards the unlocked lock symbol.
  3. Gateway MS2285 Hard Drive Replacement, Release The Battery: 步骤 3 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Release The Battery: 步骤 3 中的图像 2,2
    • Slide the long slider towards the unlocked lock icon.
    • This slider is spring loaded and may require a little force.
    • If done correctly, a click will be heard and the battery will be slightly raised.
  4. Gateway MS2285 Hard Drive Replacement, Remove The Battery: 步骤 4 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Remove The Battery: 步骤 4 中的图像 2,2
    • Grasp the battery's raised end and lift upwards.
  5. Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: 步骤 5 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Unscrew Backplate: 步骤 5 中的图像 2,2
    • Use the Phillips head screwdriver to remove the five screws holding the back plate.
    • The screws are counter-clockwise threaded.
  6. Gateway MS2285 Hard Drive Replacement, Remove Back Plate: 步骤 6 中的图像 1,3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: 步骤 6 中的图像 2,3 Gateway MS2285 Hard Drive Replacement, Remove Back Plate: 步骤 6 中的图像 3,3
    • Place fingers under back plate via the indentation and lift upwards to remove.
  7. Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: 步骤 7 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Unscrew Hard Drive Cover: 步骤 7 中的图像 2,2
    • Unscrew the six screws holding the hard drive cover in place
  8. Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: 步骤 8 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Unlock Hard Drive Cover and Hard Drive: 步骤 8 中的图像 2,2
    • Grip onto the cover and slide it away from the connector to release the cover and hard drive.
  9. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: 步骤 9 中的图像 1,3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: 步骤 9 中的图像 2,3 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive Cover: 步骤 9 中的图像 3,3
    • Grip onto the black plastic tab to lift the end enough to get your fingers under.
    • Once it is high enough, place another finger or fingers under the cover and lift straight off.
  10. Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: 步骤 10 中的图像 1,2 Gateway MS2285 Hard Drive Replacement, Remove Hard Drive: 步骤 10 中的图像 2,2
    • Use hand to grab hard drive and remove.
    • Do not touch the gold connectors.
结论
另外一个人完成了本指南。
Chris mello
于10/22/14注册
331 声望
创作了3篇指南
团队
UMass Dartmouth, Team 1-7, Shastany Fall 2014 UMass Dartmouth, Team 1-7, Shastany Fall 2014 的会员
UMASSD-SHASTANY-F14S1G7
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 21
总计 3,754
