跳转到主内容
Gateway MD2614u Wireless Card Replacement
你所需要的
  1. Gateway MD2614u Wireless Card Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Wireless Card Replacement: 步骤 3 中的图像 1,1
    • Lift off the cover.
  4. Gateway MD2614u Wireless Card Replacement, Wireless Card: 步骤 4 中的图像 1,1
    • The wireless card is located to the right of the hard drive and below the RAM.
  5. Gateway MD2614u Wireless Card Replacement: 步骤 5 中的图像 1,1
    • There are black and grey wires with gold heads attached to the top of the wireless card.
    • To remove these wires, turn the gold heads counterclockwise and pull up.
    • You will hear a snap when the heads come off.
    • It does not matter which wire you remove first, but do so one at a time.
  6. Gateway MD2614u Wireless Card Replacement: 步骤 6 中的图像 1,1
    • Remove the two screws next to the wires with a Phillips #00 screwdriver.
  7. Gateway MD2614u Wireless Card Replacement: 步骤 7 中的图像 1,1
    • The card will pop up 20 degrees and is loose enough to remove with your hand.
    • Carefully pull the card out to the left horizontally.
结论
Toni Pipes
于10/05/10注册
333 声望
创作了7篇指南
团队
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G31
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 4,451
