跳转到主内容
Gateway MD2614u Processor Replacement
你所需要的
  1. Gateway MD2614u Processor Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Processor Replacement: 步骤 2 中的图像 1,1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Processor Replacement: 步骤 3 中的图像 1,1
    • Lift off the cover.
  4. Gateway MD2614u Processor Replacement, Fan: 步骤 4 中的图像 1,1
    • Unplug the fan’s power cable, which is a group of black wires attached to a white plastic head on the motherboard.
    • Pull the plastic part of the cable, not the wires, so that the plug does not break.
  5. Gateway MD2614u Processor Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws located on opposite sides of the fan with a Phillips #00 screw driver.
  6. Gateway MD2614u Processor Replacement: 步骤 6 中的图像 1,1
    • The fan is permanently attached to the silver heat sink next to the RAM.
    • To completely remove the parts, loosen the heat sink’s four screws with a Phillips #00 screw driver.
    • Take out the screws in the numerical order shown on the heat sink.
  7. Gateway MD2614u Processor Replacement: 步骤 7 中的图像 1,1
    • Pull the fan and heat sink toward you at a 20 degree angle upward.
  8. Gateway MD2614u Processor Replacement, Processor: 步骤 8 中的图像 1,1
    在这个步骤中使用的工具:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    • The CPU is located under the heat sink you just removed.
    • It is a green card on a white plastic surface. There is a black lock on one side of the plastic.
    • Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screwdriver.
    • If done correctly, the lock makes a clicking noise when unlocked.
  9. Gateway MD2614u Processor Replacement: 步骤 9 中的图像 1,1
    • Place your fingers on opposite edges of the green card.
    • Carefully lift the CPU upward.
结论
2等其他人完成本指南。
Toni Pipes
于10/05/10注册
333 声望
创作了7篇指南
团队
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G31
4 名成员
创作了14篇指南
1指南评论
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 21
总计 7,361
