简介
You will use the fan repair guide to get to the CPU. Then, you will use the lock to remove the CPU.
工具
配件
无需配件。
The CPU is located under the heat sink you just removed. It is a green card on a white plastic surface. There is a black lock on one side of the plastic. Rotate the CPU lock 180 degrees counterclockwise with a 3.0 mm Flathead screw driver.
另外一个人完成了本指南。
一条评论
Memory address registers and memory data registers together can represent the gateway?if can how?
Jayita Roy - 回复
