跳转到主内容
Gateway MD2614u Internal Modem Replacement
你所需要的
  1. Gateway MD2614u Internal Modem Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Place the laptop so the back cover is facing up.
  2. Gateway MD2614u Internal Modem Replacement: 步骤 2 中的图像 1,1
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Gateway MD2614u Internal Modem Replacement: 步骤 3 中的图像 1,1
    • Lift off the cover.
  4. Gateway MD2614u Internal Modem Replacement, Internal Modem: 步骤 4 中的图像 1,1
    • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
  5. Gateway MD2614u Internal Modem Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
  6. Gateway MD2614u Internal Modem Replacement: 步骤 6 中的图像 1,1
    • Carefully pry the modem as to not damage any of the surrounding components
  7. Gateway MD2614u Internal Modem Replacement: 步骤 7 中的图像 1,1
    • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
  8. Gateway MD2614u Internal Modem Replacement: 步骤 8 中的图像 1,1
    • Success! You've removed the internal modem!
结论
Nelson
于03/11/14注册
201 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 6
总计 488
