1. Place the laptop so the back cover is facing up.
    • Place the laptop so the back cover is facing up.
  2. Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
    • Remove the 8 screws from the back cover using the Phillips #00 screwdriver.
  3. Lift off the cover.
    • Lift off the cover.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
    • The internal modem will be located towards the bottom right of the laptop (highlighted with a yellow square).
  6. Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
    • Using a Phillips #00 screwdriver, unscrew both of the screws that are holding the modem in place.
  7. Carefully pry the modem as to not damage any of the surrounding components
    • Carefully pry the modem as to not damage any of the surrounding components
  8. Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
    • Using needle nose pliers, carefully detach the wire connecting the modem, by applying pressure to the black tabs away from the modem itself.
  9. Success! You've removed the internal modem!
    • Success! You've removed the internal modem!
结论
Nelson
于2014年03月11日注册
201 信誉积分
创作了2篇指南
团队
UMass Dartmouth, Team 4-2, Calloway Fall 2012 UMass Dartmouth, Team 4-2, Calloway Fall 2012 的会员
UMASSD-CALLOWAY-F12S4G2
1 名成员
创作了2篇指南
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 1
过去的30天: 4
总计 210
