跳转到主内容
Gateway MD2614u Battery Replacement
  1. Gateway MD2614u Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Ensure the laptop is completely powered off and disconnected from any power source. Turn your Gateway MD2614U laptop over as shown in the image.
  2. Gateway MD2614u Battery Replacement: 步骤 2 中的图像 1,1
    • Slide and hold the battery release lock to the left.
  3. Gateway MD2614u Battery Replacement: 步骤 3 中的图像 1,1
    • Pull the battery away from the laptop.
  4. Gateway MD2614u Battery Replacement: 步骤 4 中的图像 1,1
    • Insert the new battery into the slot.
结论
To reassemble your Gateway MD2614u laptop after replacing the battery, follow the reverse sequence of the steps you took during the initial battery assembly.
Toni Pipes
于10/05/10注册
333 声望
创作了7篇指南
团队
Cal Poly, Team 21-31, Regan Fall 2010 Cal Poly, Team 21-31, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G31
4 名成员
创作了14篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 12
总计 4,065
