跳转到主内容
Gateway MA7 Fan Replacement
你所需要的
  1. Gateway MA7 Fan Replacement, Fan: 步骤 1 中的图像 1,1
    • Before starting this replacement, make sure the device is powered off and the battery is removed.
    • This particular device is missing the battery.
    • To remove your battery, slide the plastic tabs on the back of the laptop and pull the battery out of the device.
  2. Gateway MA7 Fan Replacement: 步骤 2 中的图像 1,3 Gateway MA7 Fan Replacement: 步骤 2 中的图像 2,3 Gateway MA7 Fan Replacement: 步骤 2 中的图像 3,3
    • Remove the seven 6mm screws from the back panel with a Phillips #0 screwdriver.
  3. Gateway MA7 Fan Replacement: 步骤 3 中的图像 1,3 Gateway MA7 Fan Replacement: 步骤 3 中的图像 2,3 Gateway MA7 Fan Replacement: 步骤 3 中的图像 3,3
    • Pull upwards on the top of the plastic panel to remove it.
    • With the exception of the screw marked "K", all of the screws will remain connected to the plastic piece.
  4. Gateway MA7 Fan Replacement: 步骤 4 中的图像 1,2 Gateway MA7 Fan Replacement: 步骤 4 中的图像 2,2
    • Remove the five 6 mm screws with a Phillips #0 screw driver to detach the fan and cooling unit from the motherboard.
    • The four screws on the silver metal bands of the fan will not come off of the actual component.
  5. Gateway MA7 Fan Replacement: 步骤 5 中的图像 1,3 Gateway MA7 Fan Replacement: 步骤 5 中的图像 2,3 Gateway MA7 Fan Replacement: 步骤 5 中的图像 3,3
    • Lifting from the left side of the fan, start to pull the fan off of the motherboard.
    • Be sure not to pull the fan all the way off the motherboard yet. Before it can be completely removed the cables must be disconnected.
    • There may be thermal paste adhering the fan to the motherboard. Be sure to lift the fan slowly and gently.
  6. Gateway MA7 Fan Replacement: 步骤 6 中的图像 1,3 Gateway MA7 Fan Replacement: 步骤 6 中的图像 2,3 Gateway MA7 Fan Replacement: 步骤 6 中的图像 3,3
    • In order to properly remove the fan, disconnect the cable that is attached to the motherboard.
    • Gently grasp the connecting cable from under the fan and pull it out of the socket on the motherboard to disconnect it.
  7. Gateway MA7 Fan Replacement: 步骤 7 中的图像 1,3 Gateway MA7 Fan Replacement: 步骤 7 中的图像 2,3 Gateway MA7 Fan Replacement: 步骤 7 中的图像 3,3
    • With the screws removed and the cable disconnected, just lift the fan off the motherboard to remove it.
    • When you replace the fan, be sure to reapply thermal paste here.
结论
Cameron Sheedy
于03/05/18注册
145 声望
撰写一个指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 13
总计 465
