当前版本的文档还未经巡查,您可以查看最新的已查核版本。
To prevent injury, make sure the laptop is unplugged before removing the battery.
Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
Loosen the 3mm Phillips #0 screw from the back of the WiFi card backplate.
The screw will remain in the backplate.
Lift upwards on the back plate to remove it.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
