跳转到主内容
Gateway MA6 Laptop RAM Replacement
你所需要的
  1. Gateway MA6 Laptop RAM Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Gateway MA6 Laptop RAM Replacement: 步骤 2 中的图像 1,3 Gateway MA6 Laptop RAM Replacement: 步骤 2 中的图像 2,3 Gateway MA6 Laptop RAM Replacement: 步骤 2 中的图像 3,3
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. Gateway MA6 Laptop RAM Replacement, RAM: 步骤 3 中的图像 1,2 Gateway MA6 Laptop RAM Replacement, RAM: 步骤 3 中的图像 2,2
    • Remove the seven 6 mm Phillips #0 screws from the back of the case.
    • Leave all the screws in the back plate and so you don't lose them.
  4. Gateway MA6 Laptop RAM Replacement: 步骤 4 中的图像 1,2 Gateway MA6 Laptop RAM Replacement: 步骤 4 中的图像 2,2
    • Pull upwards on the top of the back cover to remove it.
  5. Gateway MA6 Laptop RAM Replacement: 步骤 5 中的图像 1,3 Gateway MA6 Laptop RAM Replacement: 步骤 5 中的图像 2,3 Gateway MA6 Laptop RAM Replacement: 步骤 5 中的图像 3,3
    • Pull outwards on the silver metal pins to release the upper RAM module.
    • The module will automatically lift up 30° after it has been released.
  6. Gateway MA6 Laptop RAM Replacement: 步骤 6 中的图像 1,2 Gateway MA6 Laptop RAM Replacement: 步骤 6 中的图像 2,2
    • Firmly grasp the outer portion of the RAM module, and pull it outward to remove it from the port.
    • Repeat the same process for the lower RAM module.
结论
Chris Naughton
于04/07/14注册
705 声望
创作了5篇指南
团队
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G2
5 名成员
创作了20篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 1,147
