跳转到主内容
修复你的物品
维修的权力
配件 & 工具
简介
Your laptop hard drive stores all of your files, as well as your computer's operating system. A corrupt hard drive will need to be replaced for your computer to power on and run. It is common to upgrade to a larger hard drive with more storage space.
配件
没有特定配件。
  1. To prevent injury, make sure the laptop is unplugged before removing the battery.
    • To prevent injury, make sure the laptop is unplugged before removing the battery.
    • Make sure the switch in the upper right corner of the laptop is switched to the "unlock" position (toward the unlocked padlock icon).
  2. Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon. Firmly pull the battery outwards and away from the laptop. Firmly pull the battery outwards and away from the laptop.
    • Pull the switch on the upper lefthand corner of the laptop towards the unlocked padlock icon.
    • Firmly pull the battery outwards and away from the laptop.
  3. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  4. Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover. Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
    • Remove the two 9 mm Phillips #0 screws from the back of the hard drive cover.
  5. Press thumb down firmly on the hard drive and pull outwards to the side. Press thumb down firmly on the hard drive and pull outwards to the side.
    • Press thumb down firmly on the hard drive and pull outwards to the side.
结论
3等其他人完成本指南。
Chris Naughton
于2014年04月07日注册
705 信誉积分
创作了5篇指南
团队
Cal Poly, Team 6-2, Forte Spring 2014 Cal Poly, Team 6-2, Forte Spring 2014 的会员
CPSU-FORTE-S14S6G2
5 名成员
创作了17篇指南
It only took 2 minutes once I found te right screwdriver. Great aid!
Reed Roloff - 回复
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 11
总计 1,426
