跳转到主内容
Gateway M-2626u Hard Drive Replacement
你所需要的
  1. Gateway M-2626u Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Gateway M-2626u Hard Drive Replacement: 步骤 2 中的图像 1,3 Gateway M-2626u Hard Drive Replacement: 步骤 2 中的图像 2,3 Gateway M-2626u Hard Drive Replacement: 步骤 2 中的图像 3,3
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Gateway M-2626u Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,2 Gateway M-2626u Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,2
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Gateway M-2626u Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Gateway M-2626u Hard Drive Replacement: 步骤 5 中的图像 1,3 Gateway M-2626u Hard Drive Replacement: 步骤 5 中的图像 2,3 Gateway M-2626u Hard Drive Replacement: 步骤 5 中的图像 3,3
    • Using your hands, carefully pull out the hard drive from its compartment.
结论
Femi
于04/06/18注册
219 声望
创作了2篇指南
团队
UMass Dartmouth, Team S3-G7, Peak Fall 2018 UMass Dartmouth, Team S3-G7, Peak Fall 2018 的会员
UMASSD-PEAK-F18S3G7
3 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 241
