简介
If your computer is failing due to old age and you think you need a CPU replacement, follow this guide to help replace it.
  1. Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
    • Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
  2. Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
    • Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
    • Remove the header by pulling on it with two fingers.
    • Remove the six 2.5mm screws using a Phillips #1 screwdriver.
    • Remove the fan by moving it to the side and lifting it out of the computer.
    • Once the fan is removed, locate the CPU.
    • Rotate the plastic knob using a flat head screw driver as depicted in this image
    • Lift and remove the CPU from the mother board socket.
结论
Armani Tayeh
于2018年03月19日注册
411 信誉积分
创作了4篇指南
团队
UMass Dartmouth, Team S3-G2, Peak Spring 2018 UMass Dartmouth, Team S3-G2, Peak Spring 2018 的会员
UMASSD-PEAK-S18S3G2
2 名成员
创作了7篇指南
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 1
总计 32
