简介
In this guide you will learn how to access the RAM. This process is quite simple once the back panel is removed and the RAM is accessible. You can replace, clean, or simply examine the RAM for imperfections.
你所需要的
Place the laptop face down in front of you.
Locate the battery lock switches on the left and right top corners of the bottom of the device indicated by the red circles.
Pinch the switches and slide toward the edges of the computer to unlock.
Open the laptop so that the screen and keyboard are facing you.
Identify the 5 tabs above the function keys in the crevice that attaches the keyboard to the main frame.
在这个步骤中使用的工具:Plastic Cards$2.99
Begin to slide the plastic card under the top edge of the keyboard. You will hear popping sounds and the keyboard will eventually be released.
Carefully pry the keyboard from the main frame, starting at the top section.
Locate and unscrew the five screws indicated by the red circles in the picture using a Phillip's #0 screwdriver. All of the screws are 8.0 mm, excluding the top right screw which is shorter. It should be 5.0mm.
Each screw should have the word "DOOR" engraved beside or above it.
Hold the computer in your hands and use the tip of your screwdriver or a spudger to push through the bottom right hand hole left by the removed screw. This hole is shown in the picture within a red box.
The tip of the screwdriver will push against the bottom casing of the laptop and pop it away from the rest of the frame.
2等其他人完成本指南。
