跳转到主内容
Gateway KAV60 LT2016U RAM Replacement
你所需要的
  1. Gateway KAV60 LT2016U RAM Replacement, Battery: 步骤 1 中的图像 1,3 Gateway KAV60 LT2016U RAM Replacement, Battery: 步骤 1 中的图像 2,3 Gateway KAV60 LT2016U RAM Replacement, Battery: 步骤 1 中的图像 3,3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U RAM Replacement, RAM: 步骤 2 中的图像 1,1
    • The RAM is located under this cover.
  3. Gateway KAV60 LT2016U RAM Replacement: 步骤 3 中的图像 1,3 Gateway KAV60 LT2016U RAM Replacement: 步骤 3 中的图像 2,3 Gateway KAV60 LT2016U RAM Replacement: 步骤 3 中的图像 3,3
    • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
    • Use a plastic opening tool to remove the cover.
  4. Gateway KAV60 LT2016U RAM Replacement: 步骤 4 中的图像 1,2 Gateway KAV60 LT2016U RAM Replacement: 步骤 4 中的图像 2,2
    • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
    • Remove the RAM while the metal clamps are disengaged.
结论
Lydia Benjock
于10/18/13注册
1,216 声望
创作了10篇指南
团队
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G3
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 2,086
