跳转到主内容
Gateway KAV60 LT2016U Motherboard Replacement
你所需要的
  1. Gateway KAV60 LT2016U Motherboard Replacement, Battery: 步骤 1 中的图像 1,3 Gateway KAV60 LT2016U Motherboard Replacement, Battery: 步骤 1 中的图像 2,3 Gateway KAV60 LT2016U Motherboard Replacement, Battery: 步骤 1 中的图像 3,3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Motherboard Replacement, Upper Cover: 步骤 2 中的图像 1,1
    • Make sure the RAM, hard drive, and WiFi card have been removed from the computer before trying to take off the cover so they are not damaged in the process.
  3. Gateway KAV60 LT2016U Motherboard Replacement: 步骤 3 中的图像 1,2 Gateway KAV60 LT2016U Motherboard Replacement: 步骤 3 中的图像 2,2
    • Remove six (6) 5mm screws, two (2) 17.5mm screws, and three (3) 2.5mm screws from the back, using the Phillips #0 screwdriver, as marked here.
  4. Gateway KAV60 LT2016U Motherboard Replacement: 步骤 4 中的图像 1,3 Gateway KAV60 LT2016U Motherboard Replacement: 步骤 4 中的图像 2,3 Gateway KAV60 LT2016U Motherboard Replacement: 步骤 4 中的图像 3,3
    • Pry up the keyboard using a spudger or plastic opening tool in the exact location shown in the photograph.
    • Don't use a screwdriver as a pry tool as shown in this example.
    • Carefully disconnect the keyboard ribbon cable from the motherboard, and remove the keyboard.
  5. Gateway KAV60 LT2016U Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the five (5) 5mm screws shown here using the Phillips #0 screwdriver.
  6. Gateway KAV60 LT2016U Motherboard Replacement: 步骤 6 中的图像 1,2 Gateway KAV60 LT2016U Motherboard Replacement: 步骤 6 中的图像 2,2
    • Separate the upper cover from the back cover. It is possible to do this without a tool, but you may also use a plastic opening tool for added leverage.
    • Be careful to keep even pressure all the way around the cover so that it is not bent beyond repair.
    • Carefully disconnect two ribbon cables to complete the separation of the upper cover.
  7. Gateway KAV60 LT2016U Motherboard Replacement, WiFi Card: 步骤 7 中的图像 1,2 Gateway KAV60 LT2016U Motherboard Replacement, WiFi Card: 步骤 7 中的图像 2,2
    • The WiFi card is shown here.
    • Remove the one (1) 5mm screw holding the card to the motherboard using a Phillips #0 screwdriver.
  8. Gateway KAV60 LT2016U Motherboard Replacement: 步骤 8 中的图像 1,2 Gateway KAV60 LT2016U Motherboard Replacement: 步骤 8 中的图像 2,2
    • Disconnect the wires on the WiFi card. This can be done easily by applying pressure to the connections until they pop off of the card.
  9. Gateway KAV60 LT2016U Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Using a Phillips #00 screwdriver, remove the four (4) 5mm screws holding the motherboard in place.
  10. Gateway KAV60 LT2016U Motherboard Replacement: 步骤 10 中的图像 1,1
    • Remove the motherboard by lifting it gently from the bottom cover.
    • This image is the rear view of the motherboard.
结论
另外一个人完成了本指南。
Lydia Benjock
于10/18/13注册
1,216 声望
创作了10篇指南
团队
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G3
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 16
总计 1,759
