当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
When working with electronics, it is always wise to remove the power source before taking the device apart.
The hard drive is located under this cover.
Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
Use a plastic opening tool to lift the cover.
Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
Lift the silver cover; this will expose the hard drive.
取消:我没有完成这个指南。
与8其他贡献者
于10/18/13注册
1,216 声望
创作了10篇指南
徽章: 11
+ 8更多徽章
CLEM-BENSON-F13S14G3
3 名成员
创作了22篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 1
过去 7 天: 7
过去 30 天: 16
总计 1,658
