跳转到主内容
Gateway KAV60 LT2016U Hard Drive Replacement
你所需要的
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: 步骤 1 中的图像 1,3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: 步骤 1 中的图像 2,3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: 步骤 1 中的图像 3,3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,1
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 3 中的图像 1,2 Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 4 中的图像 1,2 Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 5 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 6 中的图像 1,3 Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 6 中的图像 2,3 Gateway KAV60 LT2016U Hard Drive Replacement: 步骤 6 中的图像 3,3
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
结论
Lydia Benjock
于10/18/13注册
1,216 声望
创作了10篇指南
团队
Clemson, Team 14-3, Benson Fall 2013 Clemson, Team 14-3, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G3
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 16
总计 1,658
