跳转到主内容
Gateway ID49C07U Screen Replacement
你所需要的
  1. Gateway ID49C07U Screen Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: 步骤 2 中的图像 1,2 Gateway ID49C07U Screen Replacement: 步骤 2 中的图像 2,2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: 步骤 3 中的图像 1,1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: 步骤 4 中的图像 1,1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: 步骤 5 中的图像 1,1
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: 步骤 6 中的图像 1,2 Gateway ID49C07U Screen Replacement: 步骤 6 中的图像 2,2
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: 步骤 7 中的图像 1,2 Gateway ID49C07U Screen Replacement: 步骤 7 中的图像 2,2
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: 步骤 8 中的图像 1,1
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: 步骤 9 中的图像 1,3 Gateway ID49C07U Screen Replacement: 步骤 9 中的图像 2,3 Gateway ID49C07U Screen Replacement: 步骤 9 中的图像 3,3
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: 步骤 10 中的图像 1,3 Gateway ID49C07U Screen Replacement: 步骤 10 中的图像 2,3 Gateway ID49C07U Screen Replacement: 步骤 10 中的图像 3,3
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: 步骤 11 中的图像 1,2 Gateway ID49C07U Screen Replacement: 步骤 11 中的图像 2,2
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: 步骤 12 中的图像 1,1
    在这个步骤中使用的工具:
    购买
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: 步骤 13 中的图像 1,2 Gateway ID49C07U Screen Replacement: 步骤 13 中的图像 2,2
    • Hold the tape back with one hand and pull the connector out
结论
2等其他人完成本指南。
Ryan Howlett
于03/06/17注册
267 声望
创作了2篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 330
