跳转到主内容
Gateway 600YG2 LCD Replacement
你所需要的
  1. Gateway 600YG2 LCD Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 LCD Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: 步骤 3 中的图像 1,1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 LCD Replacement, LCD: 步骤 4 中的图像 1,1
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  5. Gateway 600YG2 LCD Replacement: 步骤 5 中的图像 1,1
    • Gently unplug the LCD from the system board.
  6. Gateway 600YG2 LCD Replacement: 步骤 6 中的图像 1,1
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: 步骤 7 中的图像 1,1
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
结论
Elizabeth Mazer
于10/14/10注册
78 声望
创作了10篇指南
团队
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G10
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 1,873
