跳转到主内容
Gateway 600YG2 CPU Replacement
你所需要的
  1. Gateway 600YG2 CPU Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 CPU Replacement: 步骤 2 中的图像 1,1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 CPU Replacement, Power Button Panel: 步骤 3 中的图像 1,1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 CPU Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Remove the 5 screws holding the keyboard in place.
  5. Gateway 600YG2 CPU Replacement: 步骤 5 中的图像 1,2 Gateway 600YG2 CPU Replacement: 步骤 5 中的图像 2,2
    • Potential for device damage: When lifting the keyboard out, do not lift the keyboard up. Only fold back along the space bar edge.
    • Potential for device damage: Do not pull the black cable by the ribbon section. Only pull it from the connector itself.
    • Follow the black ribbon cable to the connector and gently pull straight up.
  6. Gateway 600YG2 CPU Replacement, System Fan: 步骤 6 中的图像 1,2 Gateway 600YG2 CPU Replacement, System Fan: 步骤 6 中的图像 2,2
    • Unscrew the four captive screws.
    • Unplug the fan from the system and pull it out. The fan unit should slide forward before coming free.
  7. Gateway 600YG2 CPU Replacement, CPU: 步骤 7 中的图像 1,1
    • Turn screw 1/4 turn to the right.
    • When reinstalling ensure proper orientation the yellow arrow on CPU should be in upper left corner
结论
另外一个人完成了本指南。
Elizabeth Mazer
于10/14/10注册
78 声望
创作了10篇指南
团队
Cal Poly, Team 20-10, Maness Fall 2010 Cal Poly, Team 20-10, Maness Fall 2010 的会员
CPSU-MANESS-F10S20G10
3 名成员
创作了22篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 1,968
