跳转到主内容
Gateway 3545GZ Hard Drive Replacement
你所需要的
  1. Gateway 3545GZ Hard Drive Replacement, Hard Drive: 步骤 1 中的图像 1,1
    • Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
    • Screw Length: 3mm
  2. Gateway 3545GZ Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Lift up the plastic plate from the outer edge.
  3. Gateway 3545GZ Hard Drive Replacement: 步骤 3 中的图像 1,1
    • Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
结论
Bryan Rickle
于09/12/16注册
1 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 9
总计 292
