跳转到主内容
加入维修社区 - 创建账户
Gas Blowback Airsoft Magazine Reassembly
你所需要的
  1. Gas Blowback Airsoft Magazine Reassembly, Gas Blowback Airsoft Magazine Reassembly: 步骤 1 中的图像 1,3 Gas Blowback Airsoft Magazine Reassembly, Gas Blowback Airsoft Magazine Reassembly: 步骤 1 中的图像 2,3 Gas Blowback Airsoft Magazine Reassembly, Gas Blowback Airsoft Magazine Reassembly: 步骤 1 中的图像 3,3
    • If you have taken down the magazine this far you can start screwing the tubes and caps. Either end of the tube will work.
    • The o-ring can be a little crushed and still work effectively just make sure the the o-ring is evenly in position.
    • The pliers technique used in the disassemble can also be used to screw the tubes back on to the rest of assemble.
    • The tubes and caps need to tightly screwed down but not overly forced.
  2. Gas Blowback Airsoft Magazine Reassembly: 步骤 2 中的图像 1,3 Gas Blowback Airsoft Magazine Reassembly: 步骤 2 中的图像 2,3 Gas Blowback Airsoft Magazine Reassembly: 步骤 2 中的图像 3,3
    • With the tubes and caps in place now is a good time check for leaks.
    • If your valves have been removed begin putting them into place.
    • Make sure that threads are line up and do not apply too much for to the valves.
    • As mentioned in the disassemble using the proper valve removal tools is always best but with care you can use standard tools as shown.
    • Once everything in place you can gas up the magazine. I recommend using a green gas can that is not at full pressure to save on gas if it turns out that there still is a leak. If the lower pressure gas does not leak try filling the magazine with a full can of gas to see if it can handle the higher pressure.
    • If your trying find where a leak is coming from you can use the silicone spray on hole magazine and look for the bubbles.
  3. Gas Blowback Airsoft Magazine Reassembly: 步骤 3 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 3 中的图像 2,2
    • If you are still struggling with leaks. You can use Teflon tape on the treads and silicone based plumbers grease on O-rings that do not move back and forth.
  4. Gas Blowback Airsoft Magazine Reassembly: 步骤 4 中的图像 1,1
    • You can now add the bb track to the rest of the magazine core.
    • Once in position make sure the nut is into position on the other side of the magazine and then add the screw back on as shown.
  5. Gas Blowback Airsoft Magazine Reassembly: 步骤 5 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 5 中的图像 2,2
    • Now you can put the small plastic piece that allows you keep the bb follower down back into position.
    • Make sure the side of the piece that sticks up is set to the back.
  6. Gas Blowback Airsoft Magazine Reassembly: 步骤 6 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 6 中的图像 2,2
    • Now add the plastic top section back onto the mag and add the pin to hold it in place.
  7. Gas Blowback Airsoft Magazine Reassembly: 步骤 7 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 7 中的图像 2,2
    • For adding the bb retention spring hold it into position with the hook section going down word and take the tiny hex screw and drive it in.
    • Make sure there is no cross threading.
  8. Gas Blowback Airsoft Magazine Reassembly: 步骤 8 中的图像 1,3 Gas Blowback Airsoft Magazine Reassembly: 步骤 8 中的图像 2,3 Gas Blowback Airsoft Magazine Reassembly: 步骤 8 中的图像 3,3
    • Take the bb follower and set into the top of the of the bb track.
    • Then take the spring and set it into position.
    • With the core of the magazines all re-assembled, hold the spring in place then slide it back into the outer shell.
    • Tap the flat section on the top to get the core into position.
  9. Gas Blowback Airsoft Magazine Reassembly: 步骤 9 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 9 中的图像 2,2
    • Now slide the bottom cover back into position.
    • This might take a slight amount of bending int get into place.
    • Be careful the metal is very soft.
  10. Gas Blowback Airsoft Magazine Reassembly: 步骤 10 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 10 中的图像 2,2
    • Now place the two 2mm hex side screws back into the position.
  11. Gas Blowback Airsoft Magazine Reassembly: 步骤 11 中的图像 1,2 Gas Blowback Airsoft Magazine Reassembly: 步骤 11 中的图像 2,2
    • If you took the bb retention piece out earlier or it came out mistake when unloading bb's this step will show you how to put it back.
    • Use a tool to hold back the spring. Once it's back grab the leg of the spring with needles nose pliers.
    • Then take the retention piece and slide it back into place.
  12. Gas Blowback Airsoft Magazine Reassembly: 步骤 12 中的图像 1,1
    • Now you can have a fully assembled and well functioning mag.
终点
101 Tech USA
于08/06/12注册
4,167 声望
创作了17篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 12
过去 30 天: 38
总计 2,960
