跳转到主内容
Garmin vívofit 2 Batteries Replacement
你所需要的
  1. Garmin vívofit 2 Batteries Replacement, Wristband: 步骤 1 中的图像 1,2 Garmin vívofit 2 Batteries Replacement, Wristband: 步骤 1 中的图像 2,2
    • Carefully peel back the wristband so the bottom of the device is facing you. Then, pull out the device from one side (on the short edge) and take the device out of the wrist band.
  2. Garmin vívofit 2 Batteries Replacement, Batteries: 步骤 2 中的图像 1,1
    • Remove the four 3.8mm Phillips #00 screws holding the device together.
  3. Garmin vívofit 2 Batteries Replacement: 步骤 3 中的图像 1,1
    • With the screws removed from the device, take the cover off the top of the device, revealing the batteries inside.
  4. Garmin vívofit 2 Batteries Replacement: 步骤 4 中的图像 1,1
    • With the cover removed, take out the two batteries currently in the device. Take note of which side of the battery is facing which way in the device. Battery removal can usually be accomplished with your fingers. If not, carefully use a nylon spudger to pull up one edge of the battery, allowing you to remove that battery.
结论
另外一个人完成了本指南。
James Hickey
于03/26/18注册
290 声望
创作了2篇指南
团队
IUPUI, Team S1-G2, Harley Spring 2018 IUPUI, Team S1-G2, Harley Spring 2018 的会员
IUPUI-HARLEY-S18S1G2
7 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 19
总计 3,390
