跳转到主内容
Garmin nuviCam LMTHD Speaker Replacement
你所需要的
  1. Garmin nuviCam LMTHD Speaker Replacement, Screen: 步骤 1 中的图像 1,2 Garmin nuviCam LMTHD Speaker Replacement, Screen: 步骤 1 中的图像 2,2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Speaker Replacement: 步骤 2 中的图像 1,2 Garmin nuviCam LMTHD Speaker Replacement: 步骤 2 中的图像 2,2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Speaker Replacement: 步骤 3 中的图像 1,1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Speaker Replacement: 步骤 4 中的图像 1,2 Garmin nuviCam LMTHD Speaker Replacement: 步骤 4 中的图像 2,2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Speaker Replacement, Speaker: 步骤 5 中的图像 1,2 Garmin nuviCam LMTHD Speaker Replacement, Speaker: 步骤 5 中的图像 2,2
    • Locate the speaker in the corner opposite of the dashcam.
    • Pry speaker out of device using a plastic opening tool.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 445
