跳转到主内容
Garmin nuviCam LMTHD Motherboard Replacement
你所需要的
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: 步骤 1 中的图像 1,2 Garmin nuviCam LMTHD Motherboard Replacement, Screen: 步骤 1 中的图像 2,2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 2 中的图像 1,2 Garmin nuviCam LMTHD Motherboard Replacement: 步骤 2 中的图像 2,2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 3 中的图像 1,1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 4 中的图像 1,2 Garmin nuviCam LMTHD Motherboard Replacement: 步骤 4 中的图像 2,2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: 步骤 5 中的图像 1,1
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 6 中的图像 1,1
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 7 中的图像 1,1
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 8 中的图像 1,1
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 9 中的图像 1,1
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 10 中的图像 1,2 Garmin nuviCam LMTHD Motherboard Replacement: 步骤 10 中的图像 2,2
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: 步骤 11 中的图像 1,2 Garmin nuviCam LMTHD Motherboard Replacement: 步骤 11 中的图像 2,2
    • Lift motherboard out of device using plastic opening tools.
结论
3等其他人完成本指南。
一条评论
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 23
总计 656
