跳转到主内容
Garmin nuvi 2460 LMT Speaker Replacement
你所需要的
  1. Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: 步骤 1 中的图像 1,2 Garmin nuvi 2460 LMT Speaker Replacement, Back Cover: 步骤 1 中的图像 2,2
    • Using a T5 Torx Screwdriver, begin unscrewing the four 11.0 mm screws from the back panel.
  2. Garmin nuvi 2460 LMT Speaker Replacement: 步骤 2 中的图像 1,1
    • Using a plastic opening tool or similar object, find the groove in the side of the device and begin prying open the back panel. Work the tool around the entire panel until it pops off.
  3. Garmin nuvi 2460 LMT Speaker Replacement: 步骤 3 中的图像 1,1
    • Lift the beige clamp using a tweezer or your fingernail and remove the connector.
  4. Garmin nuvi 2460 LMT Speaker Replacement: 步骤 4 中的图像 1,1
    • Lift the connector gently from the socket, making sure you pull in the right direction.
  5. Garmin nuvi 2460 LMT Speaker Replacement, Speaker: 步骤 5 中的图像 1,1
    • Lift and separate the speaker connector cable using a pair of tweezers.
  6. Garmin nuvi 2460 LMT Speaker Replacement: 步骤 6 中的图像 1,1
    • Gently lift the speaker out of the back cover using a plastic opening tool.
    • Apply force as needed if there is glue holding the speaker in place.
结论
Ricardo Audain
于09/07/16注册
671 声望
创作了5篇指南
团队
USF Tampa, Team 6-4, Remmell Fall 2016 USF Tampa, Team 6-4, Remmell Fall 2016 的会员
USFT-REMMELL-F16S6G4
4 名成员
创作了7篇指南
一条评论
Where do I get the parts for the garmin nuvi 2460? I can’t find anything online or ebay. I need a speaker and a microphone replacements!
Mark Peterson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 219
