跳转到主内容
Garmin nüvi 3590 LMT Battery Replacement
你所需要的
  1. Garmin nüvi 3590 LMT Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Turn the device off by pressing and holding the power button on the top left of the device.
  2. Garmin nüvi 3590 LMT Battery Replacement: 步骤 2 中的图像 1,1
    • Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
  3. Garmin nüvi 3590 LMT Battery Replacement: 步骤 3 中的图像 1,1
    • Once all of the tabs are popped out, take the back cover off.
    • The back cover is a separate piece from the device.
  4. Garmin nüvi 3590 LMT Battery Replacement: 步骤 4 中的图像 1,2 Garmin nüvi 3590 LMT Battery Replacement: 步骤 4 中的图像 2,2
    • Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
  5. Garmin nüvi 3590 LMT Battery Replacement: 步骤 5 中的图像 1,3 Garmin nüvi 3590 LMT Battery Replacement: 步骤 5 中的图像 2,3 Garmin nüvi 3590 LMT Battery Replacement: 步骤 5 中的图像 3,3
    • Use the plastic spudger to lift the battery up and away from the device.
    • Do not puncture or bend the battery. Serious health complications could occur.
结论
7等其他人完成本指南。
David
于03/11/15注册
424 声望
创作了3篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 30
总计 3,608
