简介
This guide demonstrates how to replace the motherboard in a Garmin inReach Mini. Before replacing the motherboard, the back hard case of the device must be fully removed. The battery, which is located on the inside of the back hard case, must also be disconnected from the motherboard.
Replacing the motherboard is last resort if the device is not functioning correctly. Symptoms that indicate a need for this replacement include an inability to send or receive messages, delayed responses to button-commands, or freezing or glitching screens.
The motherboard is connected to the rest of the device by a few different cables that cannot be severed, so precision is crucial.
你所需要的
Remove the five 1.8 mm screws located on the top, sides, and bottom corners of the backside of the device.
After removing the back hard case, users can access the battery on the inside of the back hard case.
Take the iFixit opening tool and insert it into the small crevices on each side of the battery. Once inserted, apply pressure downward in order to lift the battery up. Repeat on all 3 corners.
Use the T5 screwdriver to remove each 5 mm screw.
Next, use the precision tweezers with the round tips to disconnect the black antenna wire from the motherboard.
Using the precision tweezers with the curved, pointy tips, squeeze both ends together, then insert them into the bottom left hole of the motherboard. Next, gently lift up the tweezers and pull out the motherboard.
Once you've pulled the motherboard halfway out, use the precision tweezers, or your fingers, to pull the motherboard out completely.
