跳转到主内容
Garmin fenix 6X Sapphire Display Replacement
你所需要的
  1. Garmin fenix 6X Sapphire Display Replacement, Display: 步骤 1 中的图像 1,1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Display Replacement: 步骤 2 中的图像 1,2 Garmin fenix 6X Sapphire Display Replacement: 步骤 2 中的图像 2,2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
结论
3等其他人完成本指南。
matthew long
于02/22/22注册
505 声望
创作了5篇指南
团队
Clemson, Team 1-5, Hunter Spring 2022 Clemson, Team 1-5, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G5
4 名成员
创作了5篇指南
2条评论
hello matthew
where could you buy the display. i can't find any suppliers on the net
Mr. Wu - 回复
Hi! thank you for the tutorial! do you know if a non-sapphire crystal can be replaced with a sapphire one? I got the non-sapphire watch 2 years ago and I keep scratching it.
Dennis Savitskij - 回复
添加评论
浏览统计数据:
过去 24 小时: 9
过去 7 天: 70
过去 30 天: 307
总计 3,793
