跳转到主内容
Garmin fenix 6X Sapphire Battery Replacement
你所需要的
  1. Garmin fenix 6X Sapphire Battery Replacement, Display: 步骤 1 中的图像 1,1
    • Orient the watch so that the screen is face up.
    • Remove the five 6 mm black screws from the perimeter of the watch face using the T5 Torx screwdriver.
  2. Garmin fenix 6X Sapphire Battery Replacement: 步骤 2 中的图像 1,2 Garmin fenix 6X Sapphire Battery Replacement: 步骤 2 中的图像 2,2
    • Carefully lift up the watch face as it's attached to the motherboard by a ribbon connector.
    • Detach the black connector from the motherboard.
    • A spudger can be used if you have trouble prying the piece with your fingers.
    • Don't pull on the ribbon as it could tear.
    • When the ribbon is disconnected remove the watch face.
  3. Garmin fenix 6X Sapphire Battery Replacement, Motherboard: 步骤 3 中的图像 1,1
    • Remove the four 5mm silver screws on the outer part of the motherboard using the T5 Torx screwdriver.
    • Pull the motherboard out carefully as it is connected on the other side by another ribbon connector.
  4. Garmin fenix 6X Sapphire Battery Replacement: 步骤 4 中的图像 1,3 Garmin fenix 6X Sapphire Battery Replacement: 步骤 4 中的图像 2,3 Garmin fenix 6X Sapphire Battery Replacement: 步骤 4 中的图像 3,3
    • Unlock the ZIF connector and remove the ribbon connector from the back of the motherboard.
    • A Jimmy can be used if you have trouble prying the piece with your fingers.
    • Be careful not to pull on the ribbon as it could tear.
    • Remove the motherboard.
  5. Garmin fenix 6X Sapphire Battery Replacement, Battery: 步骤 5 中的图像 1,3 Garmin fenix 6X Sapphire Battery Replacement, Battery: 步骤 5 中的图像 2,3 Garmin fenix 6X Sapphire Battery Replacement, Battery: 步骤 5 中的图像 3,3
    • To remove the battery, you will need to pry it from the glue that holds it in the bottom of the watch using a jimmy.
    • Be extremely careful when prying the battery as there is a very delicate ribbon underneath the battery.
    • When the battery is disconnected from the glue, slowly pull it up out of the watch, while keeping in mind that it is connected to some leads.
  6. Garmin fenix 6X Sapphire Battery Replacement: 步骤 6 中的图像 1,2 Garmin fenix 6X Sapphire Battery Replacement: 步骤 6 中的图像 2,2
    • The battery has a few wires that are soldered into the watch leads. You will need to cut the wires using utility scissors so that you can attach a new battery.
    • When the wires have been cut, remove the battery.
    • The wires on the new battery should be soldered to the watch leads.
结论
4等其他人完成本指南。
matthew long
于02/22/22注册
505 声望
创作了5篇指南
团队
Clemson, Team 1-5, Hunter Spring 2022 Clemson, Team 1-5, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G5
4 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 30
过去 7 天: 228
过去 30 天: 977
总计 8,555
