跳转到主内容
Garmin fenix 6X Sapphire Back Cover Replacement
你所需要的
  1. Garmin fenix 6X Sapphire Back Cover Replacement, Back Cover: 步骤 1 中的图像 1,1
    • Flip the watch so the face is down.
    • Remove the five 6 mm T5 Torx screws on the back of the watch.
  2. Garmin fenix 6X Sapphire Back Cover Replacement: 步骤 2 中的图像 1,3 Garmin fenix 6X Sapphire Back Cover Replacement: 步骤 2 中的图像 2,3 Garmin fenix 6X Sapphire Back Cover Replacement: 步骤 2 中的图像 3,3
    • Use a spudger to pry the back cover of the watch off by placing it under the seam of the back case.
    • The back cover is glued on and may be difficult to remove. It might help to heat the back cover before prying in order to soften the glue. If doing so, be careful to not burn yourself.
    • This step requires a good bit of force to pry or apply heat back cover off because the back cover is glued. Be careful not to the break cover from too much force.
结论
matthew long
于02/22/22注册
522 声望
创作了5篇指南
团队
Clemson, Team 1-5, Hunter Spring 2022 Clemson, Team 1-5, Hunter Spring 2022 的会员
CLEM-HUNTER-S22S1G5
4 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 16
过去 30 天: 61
总计 2,088
