简介
This guide illustrates how to remove and replace the charging port for this device.
你所需要的
When looking at the charging port you will notice there are two screws. To remove these, you will need a T4 bit in a nut driver. After you locate these screws you will need to remove them. The screws are 5 mm long.
After the screws are removed, the charging port will lift out of the plastic case.
即将完成!
结论
另外一个人完成了本指南。
