跳转到主内容
Garmin etrex Vista Cx Charging Port Replacement
你所需要的
  1. Garmin etrex Vista Cx Charging Port Replacement, Charging Port: 步骤 1 中的图像 1,1
    • Remove the rubber grip that goes around the side of the device.
  2. Garmin etrex Vista Cx Charging Port Replacement: 步骤 2 中的图像 1,1
    • Underneath the rubber grip will also be a piece of tape over the plastic seam. You will need to take the metal spudger and break the tape along the seam.
  3. Garmin etrex Vista Cx Charging Port Replacement: 步骤 3 中的图像 1,1
    • Next you will have to use the plastic opening tool and pry at the bottom of the GPS. This will separate the front and the back of the device.
  4. Garmin etrex Vista Cx Charging Port Replacement: 步骤 4 中的图像 1,1
    • After the front and back are separated, there will be a small ribbon cable holding them together. You will need to pull straight back on the cable with fingers. This cable will pull straight out.
  5. Garmin etrex Vista Cx Charging Port Replacement: 步骤 5 中的图像 1,3 Garmin etrex Vista Cx Charging Port Replacement: 步骤 5 中的图像 2,3 Garmin etrex Vista Cx Charging Port Replacement: 步骤 5 中的图像 3,3
    • When looking at the charging port you will notice there are two screws. To remove these, you will need a T4 bit in a nut driver. After you locate these screws you will need to remove them. The screws are 5 mm long.
    • After the screws are removed, the charging port will lift out of the plastic case.
  6. Garmin etrex Vista Cx Charging Port Replacement: 步骤 6 中的图像 1,1
    • In order to replace the charging port you have to purchase a new one.
结论
另外一个人完成了本指南。
Evan Borgman
于08/28/18注册
328 声望
创作了2篇指南
团队
IUPUI, Team S1-G6, Arle Fall 2018 IUPUI, Team S1-G6, Arle Fall 2018 的会员
IUPUI-ARLE-F18S1G6
4 名成员
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 217
