跳转到主内容
Garmin Vivoactive HR Display Replacement
你所需要的
  1. Garmin Vivoactive HR Display Replacement, Display: 步骤 1 中的图像 1,1
    • Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
  2. Garmin Vivoactive HR Display Replacement: 步骤 2 中的图像 1,1
    • Insert a spudger between the display and watch body.
    • Pry upwards and work the spudger around the perimeter of the display to free it from the body.
    • The display is still attached with ribbon cables so don't remove completely.
  3. Garmin Vivoactive HR Display Replacement: 步骤 3 中的图像 1,1
    • Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
  4. Garmin Vivoactive HR Display Replacement: 步骤 4 中的图像 1,2 Garmin Vivoactive HR Display Replacement: 步骤 4 中的图像 2,2
    • Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
结论
16等其他人完成本指南。
Chris Corry
于07/05/18注册
256 声望
撰写一个指南
团队
IUPUI, Team S2-G5, Harley Summer 2018 IUPUI, Team S2-G5, Harley Summer 2018 的会员
IUPUI-HARLEY-SU18S2G5
3 名成员
创作了3篇指南
19条评论
Hello,
thanks for this. Where can i buy the new screen?
Bowland Olan - 回复
Nice guide! Thanks. But I can’t find any parts to repair my watch
Christoph Freydank - 回复
Yeah, where can we get the parts from? Also how hard is it to change the battery? Thanks for your help :)
Rick - 回复
What type of glue i use to connect the display an the body?
culibrkboj - 回复
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 30
过去 30 天: 118
总计 24,430
