跳转到主内容
Garmin StreetPilot c330 Screen Replacement
你所需要的
  1. Garmin StreetPilot c330 Screen Replacement, Outer Casing: 步骤 1 中的图像 1,3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: 步骤 1 中的图像 2,3 Garmin StreetPilot c330 Screen Replacement, Outer Casing: 步骤 1 中的图像 3,3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Screen Replacement: 步骤 2 中的图像 1,3 Garmin StreetPilot c330 Screen Replacement: 步骤 2 中的图像 2,3 Garmin StreetPilot c330 Screen Replacement: 步骤 2 中的图像 3,3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Screen Replacement: 步骤 3 中的图像 1,2 Garmin StreetPilot c330 Screen Replacement: 步骤 3 中的图像 2,2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Screen Replacement: 步骤 4 中的图像 1,3 Garmin StreetPilot c330 Screen Replacement: 步骤 4 中的图像 2,3 Garmin StreetPilot c330 Screen Replacement: 步骤 4 中的图像 3,3
    在这个步骤中使用的工具:
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Screen Replacement: 步骤 5 中的图像 1,1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Screen Replacement, Screen: 步骤 6 中的图像 1,3 Garmin StreetPilot c330 Screen Replacement, Screen: 步骤 6 中的图像 2,3 Garmin StreetPilot c330 Screen Replacement, Screen: 步骤 6 中的图像 3,3
    • Remove the three screws holding the motherboard in place.
  7. Garmin StreetPilot c330 Screen Replacement: 步骤 7 中的图像 1,1
    • Use the spudger to lift up the motherboard.
  8. Garmin StreetPilot c330 Screen Replacement: 步骤 8 中的图像 1,3 Garmin StreetPilot c330 Screen Replacement: 步骤 8 中的图像 2,3 Garmin StreetPilot c330 Screen Replacement: 步骤 8 中的图像 3,3
    在这个步骤中使用的工具:
    • To remove the ribbon cable, lift the black latch using the spudger tool.
    • Separate the connection using either your fingers, tweezers, or the spudger.
  9. Garmin StreetPilot c330 Screen Replacement: 步骤 9 中的图像 1,2 Garmin StreetPilot c330 Screen Replacement: 步骤 9 中的图像 2,2
    • Slide the spudger under the two flexible tabs located on the right and left sides of the bottom of the screen.
    • Rotate the spudger outward until the tabs are no longer holding the screen.
    • When reassembling, slide the bottom of the screen under the two permanent tabs.
    • Push the screen out from the front.
  10. Garmin StreetPilot c330 Screen Replacement: 步骤 10 中的图像 1,1
    • Separate the screen from the front cover.
结论
Adrian Leon
于10/07/10注册
173 声望
创作了3篇指南
团队
Cal Poly, Team 22-1, Maness Fall 2010 Cal Poly, Team 22-1, Maness Fall 2010 的会员
CPSU-MANESS-F10S22G1
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 15
总计 1,673
