简介
This guide will provide step by step instructions to enable you to safely and effectively disassemble your Garmin StreetPilot and remove and replace the screen, then reassemble your device.
配件
没有特定配件。
Use a plastic spudger tool to remove the plastic frame.
Insert the tool into the groove in the center of the top of the outer frame and lever it gently until it pops out.
Slide the spudger tool under the first flexible tab located on the right side of the bottom of the screen.
The tab is denoted by a red box in the photo.
There are two tabs at the top of the screen that are not flexible
Rotate the spudger outward until the tab is no longer holding the screen.
Push the screen out from the front.
Have your new screen ready to insert, making sure it is fully unwrapped.
Find the tabs used to secure the screen as highlighted in the photo.
Slide the bottom of the screen under the permanent tabs.
The permanent tabs are denoted by blue boxes in the photo.
Use the spudger tool to raise the flexible tabs in order to reinsert the screen completely into the front cover.
