跳转到主内容
Garmin StreetPilot c320 Rear Case Assembly Replacement
你所需要的
  1. Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: 步骤 1 中的图像 1,2 Garmin StreetPilot c320 Rear Case Assembly Replacement, Rear Case Assembly: 步骤 1 中的图像 2,2
    • Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
    • Pry the outer frame off the perimeter of the rear panel assembly.
    • The cover will easily pop off.
  2. Garmin StreetPilot c320 Rear Case Assembly Replacement: 步骤 2 中的图像 1,2 Garmin StreetPilot c320 Rear Case Assembly Replacement: 步骤 2 中的图像 2,2
    • Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
    • Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
    • Be extremely cautious when separating both halves, as the rear case assembly is still attached to the front case assembly via a few connectors.
  3. Garmin StreetPilot c320 Rear Case Assembly Replacement: 步骤 3 中的图像 1,1
    • Gently pull the battery cable connector from its socket on the motherboard.
    • The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
结论
Andrew Burman
于01/18/12注册
1 声望
撰写一个指南
团队
Cal Poly, Team 11-19, Maness Winter 2012 Cal Poly, Team 11-19, Maness Winter 2012 的会员
CPSU-MANESS-W12S11G19
4 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,369
