当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Use a Phillips #00 screwdriver to remove the four screws around the screen.
Gently pull from both ends of the casing to separate the front and back panels.
Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
Gently unplug the white cable connector using either your fingers or tweezers.
Carefully expose both halves of the device.
Be sure not to pull the two halves apart further than the black wire can reach.
取消:我没有完成这个指南。
2等其他人完成本指南。
与16其他贡献者
于10/07/10注册
173 声望
创作了3篇指南
徽章: 9
+ 6更多徽章
CPSU-MANESS-F10S22G1
3 名成员
创作了4篇指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,942
