简介
A step-by-step guide to replacing the screen of the Garmin Nuvi 680.
配件
没有特定配件。
Flip open the antenna on the back of the device.
Remove the two screws on the antenna cover using a T5 Torx screwdriver.
These screws are 4.42 mm long.
Use a spudger to disconnect the yellow antenna wire from the ZIF connector on the back of the motherboard.
Remove the antenna.
Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
Gently pull the ribbon cables out of their connectors. They should slide out easily.
Push the tabs towards the outside of the case, the tabs are located as shown.
Push the screen out of the case after the tabs are loosened.
Slide the screen out of the cover.
4等其他人完成本指南。
