跳转到主内容
Garmin Nuvi 680 Motherboard Replacement
你所需要的
  1. Garmin Nuvi 680 Motherboard Replacement, Outer Case: 步骤 1 中的图像 1,1
    • Flip open the antenna on the back of the device.
    • Remove the two 4.42 mm screws on the antenna cover using a T5 Torx screwdriver.
  2. Garmin Nuvi 680 Motherboard Replacement: 步骤 2 中的图像 1,1
    • Remove the antenna cover.
  3. Garmin Nuvi 680 Motherboard Replacement: 步骤 3 中的图像 1,1
    • The yellow wire is connected to the motherboard, so you cannot disconnect it until you finish opening the device.
    • Pull the antenna circuit board out of its case.
  4. Garmin Nuvi 680 Motherboard Replacement: 步骤 4 中的图像 1,2 Garmin Nuvi 680 Motherboard Replacement: 步骤 4 中的图像 2,2
    • Insert the pointed end of a spudger into the leftmost slit of the antenna case.
    • Push the spudger to the right.
    • Slide the antenna case out slowly or you may lose the antenna's spring. The spring is inside the black plastic that holds the antenna case to the device.
    • Slide the antenna case out of the device.
    • Reinstallation tip: first reassemble the antenna casing (place antenna back into its plastic cover), and then re-insert the entire assembly back into the GPS body.
  5. Garmin Nuvi 680 Motherboard Replacement: 步骤 5 中的图像 1,1
    • Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
    • These screws are 10.82 mm long.
  6. Garmin Nuvi 680 Motherboard Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 680 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Gently pull apart the front and back of the device. The front and back are still connected by ribbon cables.
    • Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
  7. Garmin Nuvi 680 Motherboard Replacement, Antenna: 步骤 7 中的图像 1,2 Garmin Nuvi 680 Motherboard Replacement, Antenna: 步骤 7 中的图像 2,2
    • Use a spudger to disconnect the yellow antenna wire from the ZIF connector by opening the brown latch holding the wire in place.
    • Remove the antenna.
  8. Garmin Nuvi 680 Motherboard Replacement, Screen Wiring: 步骤 8 中的图像 1,1
    • Do not remove the ribbon cables without lifting the latch or the cable will be damaged.
    • Lift the latches on the ribbon cable connectors. All the ribbon cables may have latches. The right most latch may have a latch that flips in the opposite direction from the others.
    • Gently pull the ribbon cables out of their connectors. They should slide out easily.
    • Do not separate the two halves of the device yet or the on/off cable may be severed.
  9. Garmin Nuvi 680 Motherboard Replacement: 步骤 9 中的图像 1,2 Garmin Nuvi 680 Motherboard Replacement: 步骤 9 中的图像 2,2
    • Gently pull the cable for the on/off button straight up to remove it.
    • The two halves of the device may now be separated.
  10. Garmin Nuvi 680 Motherboard Replacement, Motherboard: 步骤 10 中的图像 1,1
    • Use a PH1 sized Philips screwdriver to remove the two screws shown.
    • These screws are 6.88 mm long
  11. Garmin Nuvi 680 Motherboard Replacement: 步骤 11 中的图像 1,2 Garmin Nuvi 680 Motherboard Replacement: 步骤 11 中的图像 2,2
    • Carefully separate the motherboard from the outer case or the speaker and battery cables may be damaged.
    • Use a spudger to lift the edge of the motherboard.
  12. Garmin Nuvi 680 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Gently unplug the cable for the battery
    • Gently unplug the cable for the speaker.
  13. Garmin Nuvi 680 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Lift the motherboard out of the outer case.
结论
另外一个人完成了本指南。
Chris Marzano
于01/20/11注册
968 声望
创作了6篇指南
团队
Cal Poly, Team 5-22, Amido Winter 2011 Cal Poly, Team 5-22, Amido Winter 2011 的会员
CPSU-AMIDO-W11S5G22
5 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 9
总计 3,644
