跳转到主内容
Garmin Nuvi 65LM Car Charger Fuse Replacement
你所需要的
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: 步骤 1 中的图像 1,3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: 步骤 1 中的图像 2,3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: 步骤 1 中的图像 3,3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 65LM Car Charger Fuse Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 65LM Car Charger Fuse Replacement: 步骤 2 中的图像 3,3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: 步骤 3 中的图像 1,1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
结论
Kai Ling Liang
于04/26/15注册
246 声望
创作了2篇指南
团队
Cal Poly, Team 15-3, Amido Spring 2015 Cal Poly, Team 15-3, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G3
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 2,067
