跳转到主内容
Garmin Nuvi 65LM Battery Replacement
你所需要的
  1. Garmin Nuvi 65LM Battery Replacement, Plastic device casing: 步骤 1 中的图像 1,2 Garmin Nuvi 65LM Battery Replacement, Plastic device casing: 步骤 1 中的图像 2,2
    • Place the device on a flat surface with the screen facing down.
    • Remove the four 4.80 mm T5 screws on the corners of the device with a T5 Torx screwdriver.
  2. Garmin Nuvi 65LM Battery Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 65LM Battery Replacement: 步骤 2 中的图像 2,2
    • There is a ribbon cable that will still connect the front and back panels once they are pried part.
    • Use the plastic opening tool to gently pry apart the front and back casing panels. Repeat this at multiple locations around the edge of the device. You should hear the clips that hold the front and back together pop apart.
    • Once there is a large gap between the from and back casing panels, use your hands to separate the two halves.
  3. Garmin Nuvi 65LM Battery Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 65LM Battery Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 65LM Battery Replacement: 步骤 3 中的图像 3,3
    • Use a spudger to pop up the ZIF connector tab that fastens the ribbon cable to the motherboard.
    • Gently pull the front panel away and set it on your flat work surface.
  4. Garmin Nuvi 65LM Battery Replacement, Battery: 步骤 4 中的图像 1,3 Garmin Nuvi 65LM Battery Replacement, Battery: 步骤 4 中的图像 2,3 Garmin Nuvi 65LM Battery Replacement, Battery: 步骤 4 中的图像 3,3
    • Make sure the GPS is laying on a flat surface with the open side showing.
    • Unscrew the four marked 4.00 mm screws with a T5 torque screwdriver
    • Be sure to keep track of where you place the screws. A magnetic project mat works great for this.
    • Gently lift the motherboard off of the plastic casing.
    • The speaker and battery are still connected to the motherboard so do not pull the motherboard completely away from the casing.
  5. Garmin Nuvi 65LM Battery Replacement: 步骤 5 中的图像 1,3 Garmin Nuvi 65LM Battery Replacement: 步骤 5 中的图像 2,3 Garmin Nuvi 65LM Battery Replacement: 步骤 5 中的图像 3,3
    • Turn the motherboard over to find the plug which connects the battery to the motherboard.
    • Gently disconnect the plug by catching on the raised rib of the plug with your fingernail. Then pull the plug away from the connection.
  6. Garmin Nuvi 65LM Battery Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 65LM Battery Replacement: 步骤 6 中的图像 2,2
    • Set the motherboard down out of the way of the battery.
    • Using the flat end of the plastic opening tool carefully pry the battery and its adhesive away from the casing.
    • The adhesive holding the battery down is very strong. Prying the battery up may take some force but go slowly and carefully in order to avoid damaging the battery.
    • Once most of the adhesive is unstuck from the casing, use your hands to remove the battery completely.
结论
4等其他人完成本指南。
Kai Ling Liang
于04/26/15注册
246 声望
创作了2篇指南
团队
Cal Poly, Team 15-3, Amido Spring 2015 Cal Poly, Team 15-3, Amido Spring 2015 的会员
CPSU-AMIDO-S15S15G3
4 名成员
创作了6篇指南
3条评论
my garmin gps I need a new power pack for it, it plugs into the cigarette lighter. tell me how to order or where do I order.
vickie - 回复
it doesn't have screws anywhere
vickie -
Excellent guide! A little more detail about how the ZIP cable connection is made would add to this
leerw - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 30
总计 3,697
