跳转到主内容
Garmin Nuvi 56LMT Motherboard Replacement
你所需要的
  1. Garmin Nuvi 56LMT Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Power off the Garmin Nuvi 56LMT before disassembling.
    • This will teach you how to replace the motherboard of the Garmin Nuvi 56LMT
  2. Garmin Nuvi 56LMT Motherboard Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 56LMT Motherboard Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 56LMT Motherboard Replacement: 步骤 2 中的图像 3,3
    • Remove the 11mm screws on the back side of the case with a T5 torx screwdriver.
    • Then, use the plastic opening tool to carefully pry the case open.
  3. Garmin Nuvi 56LMT Motherboard Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 56LMT Motherboard Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 56LMT Motherboard Replacement: 步骤 3 中的图像 3,3
    • Use the plastic opening tool to carefully pry the battery from the case.
    • Then remove the 5mm screws that are present on the motherboard.
    • Disconnect the battery from the motherboard, by pinching the wires and pulling straight out.
  4. Garmin Nuvi 56LMT Motherboard Replacement: 步骤 4 中的图像 1,1
    • Remove the ribbon connecting the motherboard to the screen by using the wedge to peel back the clasp holding the ribbon in place.
  5. Garmin Nuvi 56LMT Motherboard Replacement: 步骤 5 中的图像 1,1
    • The speaker is soldered to the motherboard so they need to be removed together. Use the plastic opening tool to remove the speaker from the case.
结论
Ryan Bliss
于09/28/17注册
101 声望
撰写一个指南
团队
USF Tampa, Team S3-G5, Nance Fall 2017 USF Tampa, Team S3-G5, Nance Fall 2017 的会员
USFT-NANCE-F17S3G5
3 名成员
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 307
