跳转到主内容
Garmin Nuvi 50LM Speaker Replacement
你所需要的
  1. Garmin Nuvi 50LM Speaker Replacement, Speaker Replacement: 步骤 1 中的图像 1,1
    • Place the LCD screen is face down on a flat surface.
    • Make sure the side containing the speaker and the charging port is facing up.
  2. Garmin Nuvi 50LM Speaker Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 2 中的图像 3,3
    • Remove the four 9 mm screws on the back of the GPS unit using the Torx T-4 screwdriver found in the iFixit Pro Tech Tool Kit.
  3. Garmin Nuvi 50LM Speaker Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 3 中的图像 3,3
    • Gently pry open the device with the iFixit Plastic Opening Tool found in the iFixit Pro Tech Tool Kit.
    • Be careful not to damage the orange ribbon cable and the motherboard.
  4. Garmin Nuvi 50LM Speaker Replacement: 步骤 4 中的图像 1,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 4 中的图像 2,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 4 中的图像 3,3
    • Once the GPS is open, identify the black and blue wires connecting the black speaker to the green motherboard.
    • The black wire is located closest to the speaker.
    • The blue wire is located farthest from the speaker.
  5. Garmin Nuvi 50LM Speaker Replacement: 步骤 5 中的图像 1,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 5 中的图像 2,3 Garmin Nuvi 50LM Speaker Replacement: 步骤 5 中的图像 3,3
    • Cut both wires using a pair of wire cutters.
  6. Garmin Nuvi 50LM Speaker Replacement: 步骤 6 中的图像 1,2 Garmin Nuvi 50LM Speaker Replacement: 步骤 6 中的图像 2,2
    • Solder the wires of the replacement speaker back onto the small silver squares located on the motherboard using the iFixit Soldering Station.
    • Be careful when using the soldering iron, the temperature can reach 600F.
    • Solder the black wire onto the motherboard on the port closest to the speaker and solder the blue wire onto the motherboard on the port farthest from the speaker.
结论
另外一个人完成了本指南。
Maurice Thomas
于10/13/15注册
664 声望
创作了5篇指南
团队
一条评论
Where would you get the replacement speakers??
abby dog - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 17
总计 2,606
