跳转到主内容
Garmin Nuvi 50LM Power Button Replacement
你所需要的
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: 步骤 1 中的图像 1,2 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: 步骤 1 中的图像 2,2
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: 步骤 2 中的图像 1,2 Garmin Nuvi 50LM Power Button Replacement: 步骤 2 中的图像 2,2
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 50LM Power Button Replacement: 步骤 3 中的图像 2,2
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
结论
2等其他人完成本指南。
Maurice Thomas
于10/13/15注册
664 声望
创作了5篇指南
团队
3条评论
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - 回复
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - 回复
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 24
总计 6,843
