当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
即将完成!
终点
另外一个人完成了本指南。
一条评论
Do you know if there is any point on the motherboard where you could attach an external antenna? Or is the internal antenna removable to be replaced with an external or hacked to connect via a cable run to the outside of the device?
Did you happen to take a picture of the underside of the motherboard?
Thanks!
