跳转到主内容
Garmin Nuvi 2797LMT Motherboard Replacement
你所需要的
  1. Garmin Nuvi 2797LMT Motherboard Replacement, Motherboard: 步骤 1 中的图像 1,1
    • Before you begin make sure to turn off your GPS.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 2 中的图像 3,3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 3 中的图像 1,3 Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 3 中的图像 2,3 Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 3 中的图像 3,3
    • With the device opened, carefully remove the ribbon from the motherboard.
    • Unplug the three wire connectors from the motherboard.
  4. Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 4 中的图像 1,1
    • Using your T-4 Torx Screwdriver, unscrew six 1.58 mm T-4 Torx screws from the motherboard.
  5. Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 5 中的图像 1,2 Garmin Nuvi 2797LMT Motherboard Replacement: 步骤 5 中的图像 2,2
    • Now remove the motherboard out of the device. You will have two separate pieces.
结论
另外一个人完成了本指南。
Isaias Silva
于10/13/15注册
133 声望
撰写一个指南
团队
一条评论
Do you know if there is any point on the motherboard where you could attach an external antenna? Or is the internal antenna removable to be replaced with an external or hacked to connect via a cable run to the outside of the device?
Did you happen to take a picture of the underside of the motherboard?
Thanks!
Dragon - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 13
总计 1,235
