跳转到主内容
Garmin Nuvi 2797LMT Battery Replacement
你所需要的
  1. Garmin Nuvi 2797LMT Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Before you begin make sure to turn off your GPS.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT Battery Replacement: 步骤 2 中的图像 1,3 Garmin Nuvi 2797LMT Battery Replacement: 步骤 2 中的图像 2,3 Garmin Nuvi 2797LMT Battery Replacement: 步骤 2 中的图像 3,3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT Battery Replacement: 步骤 3 中的图像 1,2 Garmin Nuvi 2797LMT Battery Replacement: 步骤 3 中的图像 2,2
    • With the device open, locate the battery with its wire connector plugged into the motherboard. Now delicately detach the battery connector from the center by inserting a spudger underneath the power wire and lift up.
  4. Garmin Nuvi 2797LMT Battery Replacement: 步骤 4 中的图像 1,1
    • Now using the small plastic opening tool, pry the battery up from the sides.
    • The battery has been attached with strong adhesive so you will need to use a little bit of force when prying it out.
结论
另外一个人完成了本指南。
baileykaytar
于10/13/15注册
366 声望
创作了2篇指南
团队
3条评论
Your sub-par tools broke when following the directions exactly. Last time I'll be purchasing any of your items, and Ill be disputing the charges on my card for this kit.
Game Science - 回复
Thanks.
But before I get going, which model or type of battery do I need. Garmin does not seem to sell them separately as far as I can see.
GregM
cagmccarry2 - 回复
Instructions very lacking. To replace the battery go to https://www.youtube.com/watch?v=OcoZC2Fk.... Much, much better instructions.
allen1 - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 20
总计 2,406
